TD,
I wasn't really thinking of tons of parts, just parts and stuff in general vs changing out
the defective pump.
You, probably like me, have been building, fixing, repairing, fabricating and experimenting with things most of our lives. Possibly because we like to and/or had to. Given that we have lots of parts and pieces in our workshops. And we only have to go to the parts bin to find a part, bolt or screw that we need. If not, we can go to the scrap metal pile, find something close enough, cut it out, bend it, drill the holes, spray some wrinkle paint on it and we have a good looking mounting bracket for a gauge that we scrounged from somewhere.
Not knowing the mechanical knowledge and/or ability of the OP or the other readers and/or
parts they may already have, I just figured it would be the easiest fix. As long as the
rest of the system is functional.
Yes, a boost gauge may or may not be needed, but if you're going to start doing mods and
upgrades, you might as well start putting it all together. Boost, EGT and Tranny gauges.
Then you need some sort of mounting system for the gauges. Then there is wires, fuse holders and other related things to get them all mounted up securely. Then of course there's the TM, whether homemade or bought. You have to take the vacuum actuator off the turbo and mount up the TM. Then you have to adjust it, either with the boost gauge or by experimenting. Then find the right belt for your truck.
It's not that I against a TM, any experimenting or homemade mods, I just thought unbolting the old vacuum pump and replacing it with a working one would be the easiest and get the guy back on the road the fastest and cheapest with the least amount for fiddling around. And trust me I've done more than my share of fiddling around.
No disrespect intended.
