Using Timbrens along with Cognito Leveling Kit?
NNYdiesel
Recruit
Is it safe to use Timbrens for the front end if you have a cognito leveling kit installed? I am running a 8.5' Fisher Stainless V.
I don't see why not. I did it for 1 season before I lifted the truck. I was running a Western Unimount MVP 8.5.
No issue, just make sure your plow is set to the correct height per the installl instructions. If the mount is to high it will cause faster wear and might "hook" more on a gravel drive. IIRC Blizzard is 12 1/2 to CL of the mount, Western is 14 3/4 and Fisher is 13.....
They take like 15 minutes to install I hope you are not paying alot them to install for you. I didn't even have to pull the tire.
And where abouts is NNY to you. lol I am from carthage
Right down the road just outside of Dexter actually. I am usually out on FT. Drum quite a bit. Do you work out there too?
