Upper Oil Pan Removal
Status
Not open for further replies.
ripmf666
Registered user
Kansas City Mo
Service Information
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do>Document ID: 725179 <HR>
Tools Required
J 37228 Seal Cutter
    <LI type=1>Remove the oil level indicator tube bracket bolt. <LI type=1>Remove the oil level indicator tube.
    <LI type=1>Remove the two oil pan to flywheel housing bolts (denoted by black triangles).
    <LI type=1>Remove the 24 upper oil pan bolts using a long bit 6 mm hex driver. <LI type=1>Seperate the upper oil pan from the engine block using J 37228 .
  2. Remove the upper oil pan.
© 2010 General Motors. All rights reserved.
</FORM>
Status
