packratt
Active Member
Went to get an alignment. Needed pitman arm, idler arm, both ball joints on one side and upper control arm bushings on one side.
Said screw it and got a shop I deal with to do the lower ball joint and pitman arm. Figured I'd do the upper CA bushings on both sides myself. How do you get that FN outer sleeve out of the CA? Burnt the rubber out and due to failing light only beat on it a little with a BFH. There's bound to be an easier way.
