dirtfarmer629
Recruit
Well my truck had started overheating when it was idling so I decided it was time to upgrade the fan clutch. While doing it I decided to upgrade the fan also. I used a AC-delco fan clutch from a late year 6.5. Then put a DMAX fan on it. Got both of them off amazon for less then 120 dollars, thanks to a thread I seen on here. It was one of the easiest upgrades I have done everything just bolted right up. It really seems to move alot of air.
I also have had bad luck with the factory style lift pump lately so decided to upgrade this also. I got a lift pump and filter kit from pmdcable. The challenge with this that I found out is on a single cab long bed truck there is really no where to mount the kit on drivers side frame. So this is what I came up with. I put it on the inside of passenger side frame where there was plenty of room.
I took my time planning out how to run the fuel line making sure not to have any sharp corners and putting it places where it is well protected.
I used the fittings from pmdcable also which made the job easier.
I am going to build another plate to bolt under the pump and filter to protect it since this is a farm truck. Also get something to put around the fuel line and wires to protect them.
