So I've got some electrical gremlins in my turn signals with "hyperflashing" on the bad (passenger) side. So after changing out bulbs and cleaning sockets, here is what I have:
On the presumed good side with headlights on and no turn signal: inner amber light is lit, outer is not (I thought that was supposed to be lit but could be wrong).
Good side headlights on, turn signal on: amber lights and side marker flash alternately.
Good side headlights off, turn signal on: amber lights and side marker flash together.
Bad side headlights on, turn signal off: no amber lights or side marker.
Bad side headlights on, turn signal on: amber lights and side marker flash together and are dim, hyper flash and now some slower flashing.
Bad side headlights off, turn signal on: amber lights and side marker flash together and are dim, hyper flash.
Headlights off, hazards on: all lights flash together, no hyperflash but dim on the bad side.
Headlights on, hazards on: amber and side marker on good side flash alternately, amber and side marker on bad side flash together and are dim but no hyper flashing.
Note that all tail lights are the same brightness and flash at the same rate as the corresponding front lights. Headlights are on a relay harness but that shouldn't be affecting the turn signals which are still on the factory wiring.
I'll be checking and cleaning grounds when there is more daylight out but I'm looking for other ideas or suggestions of things to check, maybe a relay somewhere? And where are the most relevant grounds (I think there are a couple on the radiator support and there's that one on the passenger side body by the battery)?
