Big T
My left turn signal flashes rapidly (aka Hyper Blinking) on both the dash light and the front turn lights, while the right side flashes at a normal speed. This is a recent phenomena. Also, the left rear brake light and turn signal do not work. Bulb is not burned out. Wiring at the trailer plug also has rapid left turn indicator. Tried to trouble shoot the problem this evening but made no progress. The rear light problem appears to be no power through to the light socket.
Separately, right HID LO head light has trouble staying on all the time. It will suddenly shut off, but I can get it back on by turning the light switch off, then on again, or by turning on the HI beams. Thought it was a loose connection at the ballast, but that did not appear to be the case and that did not solve it.
Guess my truck is suffering from not enough attention.
