540s10
how much side to side play is too much?
I think the seals in mine are junk,
I had both the upper and lower intakes off and cleaned them spotless o the inside, and have had the CDR venting to atmosphere since. I have oil in the intake now, and also it burns blue smoke when reved up in park, which takes a minute to clear away after its brought back to idle.
can't do any road testing as its not registered yet.
should i pull the compressor housing off and brake clean the impeller and housing to clean it up and then see if it gets wet inside?
