juddspaintballs
my balls are painted!
I'm at work and my wife is at home. 1999 Suburban 6.5L 256k miles. She drove the Suburban around today already. She claims that when she got home earlier today the little light that indicates drive, neutral, reverse, park was out. It may have been out longer than today, who knows.
Anyways, she called and said it won't start. All functions work when the key is turned backwards (windows, wipers, etc.). Turn the key forward and the wait to start light comes on and you can hear the lift pump working. Turn the key to start and nothing. I had her check fuses under the hood and in the dash. She found no broken ones. I had her switch the starter relay with the AC relay and that didn't change anything. I know if I were home I could check the starter and such to make sure it was getting power. At this point my best guess is the solenoid probably went bad, but it's hard to tell from here at work.
Any other things she can check tonight or I should look for when I get home tomorrow? Also, how hard is it to remove the starter?
