D2 Cat
Friends 95, 6.5 TD starts and runs with out the fuel relay plugged in.
When the engine is turned off the LP is running because it continues for a few seconds.
We also opened the needle valve at the WIF hose with the engine running. Fuel ran out the line and engine continued to run----so doesn't this indicate the LP is pumping?
We installed a new relay, turn key to start position---still no LP.
What would cause this?
