PhattDaddy94HD
Thanks to Burning Oil for the help when I relocated my pmd. Panicked when I had to figure out how to get my resistor out of the old pmd mounted to the pump. Easy tip, remove top front screw and drive a small flat screwdriver down and break off the bottom front screw then do the same to both back screws.Then you can get to the resistor.
