Tinker
Active Member
I had nearly the same symptoms as detailed in this thread: https://www.thetruckstop.us/forum/threads/smoking-pmd.48938/
Engine ran away, wouldn't respond to throttle input. Smoke and burning smell from the PMD. 4-year history of occasional stalls with immediate restarts and also fishbiting under load (like going uphill).
I did all of the normal troubleshooting (followed the guide at Accurate Diesel) and each point seemed to checked out well enough. The thread referenced above has been very helpful. All roads seem to lead to either electrical or IP or both.
I've pulled the valley harness and checked the continuity on all wires leading to the PMD and optical sensor. No shorts in testing, no notable damage (one pinhead sized nick in a fairly safe area that I'll wrap up). I have a hard time believing this is just an R2 of the IP but that seems the logical next step. I just thought I'd post this to see if there are other ideas before I spend for the IP.
Is there anything else I can check in the harness? Any other potential source of shorting? Any alternative reason a PMD would get so hot it starts smoking? It was in the original location, but I'm thinking something sudden that led to catastrophic failure.
Prior to pulling the intake apart, I had tried multiple PMDs including brand new ones with no result so I'm reasonably confident it's not just the PMD.
Thanks so much for your help.
