Trickle charging batteries
hookedup50
MA
On a dual battery setup, is there any harm in trickle charging batteries while installed in the truck. Will both the batteries charge by plugging onto one battery. Or should I disconnect them and charge them separately, like I usually do. This is more of a curiousity question than anything. I'm about 3 days out before starting the truck for the first time since Oct. Its 10 degrees out here and I can't imagine them having enough juice to start, even with block heater plugged.
Thanks, I used to have issues with the OEM battery cables, like if you charged or jumpstarted from I believe the pass side battery, the cables would melt. The truck has been a different animal when starting, with raceday cables and glow harness.
I periodically put my old trickle charger on my batteries, just to keep them topped off or maintained. As Will stated, if you charge one, they both get a little juice, so it takes a little longer to charge the 2 batteries.
I do this on my tow rig with one of the new fancy chargers. Like RI mentioned, it just takes a little longer. Just for grins, I alternate which battery gets the clips.
Consider getting a small solar panel that plugs into the cigarette lighter. Just make sure to un-plug it *before* starting as they do not like receiving current. (Don't ask how I know ;) ). The solar panels will also work pretty well with indirect light.
