I have a 1995 chevrolet 1500 4x4 with a 6.5 and the 4L80E.
My transmission is on its way out, and I am going to have to replace it at some point, probably sooner than later.
From searching, I have figured out that a 1995/1996 transmission is the only "direct replacement".
What do the line adapters look like that are needed for the newer transmission to be installed? And other than the adapters, is it plug and play?
Is a transmission from a gasser compatible?
What identifying marks are on the 1995/1996 transmission?
Thank you.
Thank you.
