MrMarty51
Wanting to fill a blank hole in a gauge pod that sits atop of the dash on My truck. Looks mighty ugly glaring back in my direction.
Transmission is the 4L80E and I am wondering what the max pressure electronical gauge would not be overtaxed with pressures beyond its capabilities.
I have done some online searching and the numbers comes from 350 PSI to 500.
I do see that VDO makes a 500 PSI gauge that will fit.
IIRC, the opening size is 2-1/16th inch.
If there is more than one pressure port for gauges then I would install two sending units and a switch to transfer from one sender to the next.
Dont know what I’ll be able to do if there are three ports.
