BIGR
Lucky To Be Here
Well I guess finally my truck has got the dreaded leaking transmission lines at 26,983 miles. Probably been leaking for a little while, but was not leaking about 5000 miles ago. I was crawling under the truck to change the oil and noticed the fluid on the lines at the front right area. I guess its those sorry crimps on the lines thats causing the problems. Is the only sure solution is to replace the lines? Since I am beyond the 3 years on the warranty I guess I am out of luck, getting the dealer to do anything. You guys have any ideas?
