devildogadam
Active Member
I am buying a 1994 k2500 (6 lug) with a 350/nv4500 in hopes of pulling the Tran to swap into my diesel. My question is will the flywheel and clutch off of that truck bolt up and work on mine. All my in for is in my sig. I will probably be replacing clutch but I am not to spur if the flywheel will work. Any input will help. Thanks
