Transgo JR/ VB problem
escalante127
Hey guys im new to this forum and i have a problem. I just installed a transgo jr. i put everything back together, put trans oil in started the truck up and put it in reverse and it didnt do anything. it said shift inhibited shift to nutral. when i put it into drive it would move alittle not much. then the check engine light came on i tried checking it with the banks pda but it couldnt read it. anyone know what it could be? any info would be helpful
Thank you
which error codes did you get?? Did you clean the screens on the solenoids when you had them out???
i dont know what code i got i dont have a code reader other thank quadzill and banks pda and no i didnt clean the screens on the solenoids when i had them out. What should i clean them with?
thanks alot for your help but i found the problem. i feel like a dumb a$$ i didnt put one of the clips that hold that wire harness for the solenoids all the way in and one of the solenoids just came out. but agian thanks for the help
