I think I need to upgrade my 6 speed with something that will give it better holding power. I was pulling my trailer (about 5-6000 lbs) last weekend and on some inclines I could feel the transmission slipping at lower rpm's and my Edge Insight gauge showed TCC slippage. When I would shift down and increase rpm it wouldn't slip (line pressure increased?). What upgrade do you suggest I want to run fairly high hp eventually but cant afford a complete rebuild at this point so what can I do with the stock clutches but still get good holding power. Thanks for your help. 6k miles on truck.
