Tranny Fluid
Will
Boobies make me happy
Mt. Pleasant, IA
How many quarts of ATF Dex III do I need for a complete rebuild on an Allison? Also where is a good place to get Mobil 1 synthetic ATF?
18-20 i believe which equals out to 5 gallons. Its a thirsty trans. I thin with my deep pan i used a little under 6 gallons
The guys at the GM parts desk said 12.7 for stock pan. I've got 14 qts of Mobil 1 full syn ATF coming.
after searching a little bit that sounds right. I dont know what i was thinking, mine took a lot but that deep pan added quite a bit of capacity
How much is that 14 qts costing?
42 bucks for 6qts. I am getting it through the distributor that delivers our different hydraulic oil and grease at work so I think I'm getting it at close to cost. Talked to the guy that is going to help do the tranny and he said get 20 just to be safe. Works for me, any extra can sit on the shelf in the garage.
