BigDogYJ
Here's an interesting one...
I finally got around to adding reverse lights in my bumper and decided to wire them up and just use the Trailer Backup lights circuit to trigger my relay. So I get all the wiring in place soldered, heatshrinked, etc. I'm happy its all done, I go to test it and nada. checked for voltage at the relay, 12v battery good, ground good. No 12V from Trailer Reverse lights wire. no problem check fuse. Fuse is good. But there's no 12v power to the fuse slot at all (TRL B/U). Pulled up the fuse box, there's the light green wire coming from that slot going into the harness that runs under the truck but that fuse slot is just dead.
Did some quick searching online and a couple other folks experienced the same issue (no 12v power at the fuse box) but never had any resolution. Anyone else have issues with the trailer backup lights circuit? Can anyone check to see if their truck has power at that fuse? My wife 04 Yukon 1500 is 200 miles away otherwise I'd check it (but figured I'd ask). I ended up splicing into the actual truck reverse lights since those work fine, but just curious why I don't have power at that fuse, seems odd. I was looking through the wiring diagram and it seems it is controlled via the TRUCK B/U fuse as well as the NSBU switch on the trans. I didnt go down to the switch yet to check but I guess I can check that next.
Anyways just curious.
