Tomco U2 air quick disconnet
3500GMC
What T F, over
Nashport, Ohio
I am on the hunt for at least 3 or 4 of these air QD's.. They are compatible with the common 'industrial' 1/4" nipples. They can accomodate lincoln and tru-flate too. Anybody use these? Where to buy?
They are nice pieces, you can slide a collar to shut off the air to the tool, which also acts as a safety feature for when you disconnect the air tool, keeping the nipple from becoming a projectile.
Here is a PDF of the QD:
View attachment 79117_tomco-pg3_2007-10_lo.pdf
Those are nice too.
These Tomco deals are aluminum. There is a wear factor after several years. My original lasted 15. Nobody has them locally anymore. Which sucks.
I go thru them pretty fast. I usually only get one year out of the steel or brass, even the brass ones use steel balls and springs.
