Hi,
new to the forum and new to 6.5td. Recently bought a 95 k1500 suburban as a family hauler (boy, do I love the space :smile5. And I'm trying to decide to chip it or not. These engines have a fairly poor reputation here in Norway, but when you look closer it's mainly related to PMD failures and "heavily abused" engines. When it comes to engine failures it is often said that chipped engines are heavily in majority, and chipping is usually not recommended if you want the engine to live a long and happy life..
However, even though the engine is fairly fresh, the rest of the burb is fairly old and with a somewhat high mileage and will probably be worn out long before the engine if I leave it stock and handle it with care. So why not get the best out of the engine while the burb lasts, I reckon..
So, how much (if not at all) will I compromise the reliability of the engine if I chip it? I'm looking for increased mileage and performance for non-towing setup (no heavy hauls), any recomandations on chips/vendors? As far as I understand some chips will give me better glow plug cycles (it's quite cold here in the wintertime) and less wear on the tranny with better shift programs?
Some background info:
The engine has recently been rebuilt (only 20-25.000 km since) with reman block and all new internals, I think the heads, the turbo and the IP and injectors were re-used. The rest of the truck has run 240.000km, tranny shifts good.
Mods that were already done when I bought it are 4" straight pipe exhaust, Holley blue lift pump with pressure gauge, extra diesel filter, increased diesel flow to IP, boost-master and boost gauge, relocated FSD (on cooling ribs behind bumber) with #9 resistor, and tranny temp gauge. Gonna put exhaust temp gauge on, and most likely a silencer on the exhaust.
I'm running at best 16 mpg, but a heavy foot quickly lowers it to 14 mpg. Which I often have, and sometimes WOT when passing other cars (there are not many roads here with two or more lanes in one direction..) Tires are 275/75-16 BFG AT. I'm not gonna haul anything substantial behind it, we got an 89 F250 which we subject to the heavier tasks. It's a pure family hauler.
