titan tank q
dentpusha
LOCKED&LOADED
a-town texas
What would cause my low fuel light to come on when i kno the tanks well over half full.It will come on for a few miles then just go off at random while driving.i thought that these at least kinda worked with the oem fuel gauges,but mine dont seem to fill up.i did the lift pump and the titan tank at the same time.thanks for any info
does is to it sporaticly no matter how much fuel is in the tank? could be a bad ground if so.
keith check the float arm to make sure it's not bent upwards.
