Tire Pressure
60 all around unless loaded, then 80 in the rear. the lablel called for 40 in the front but I find the handling sloppier then.
60 front, 65 rear.....loaded or unloaded. typically i have some pretty heavy loads on mine...... don't really view 9500 as a load form my max
Not a load for my 6.5 either... just my everyday weight. Separates the men from the 7-8k boys. When you're starting point is higher than the GVW's of most others truck, its a real truck.
