Our property has a little-used unpaved drive that traverses a fairly steep slope. I use this drive when unloading one-ton pallets of the wood pellets we use to heat the house. I have to time my deliveries to avoid driving up the hill when it's wet and muddy. This year, I got the timing wrong and got stuck at the bottom of the frozen hill with a foot of snow on the ground.
I ordered a set of chains from tirechains.com, put them on my outer real wheels, and drove up the hill like it was dry pavement.
I went with the "FL750 Square Link Boron Alloy" chains for about $100 delivered. I thought about the emergency strap-on chains, which would have been *much* easier to install, but I went with the real chains. They rate well for on and off road, mud and ice.
I've owned chains in the past, but this is the first time I ever had to actually use them. I didn't expect to enjoy installing chains on a stuck vehicle, but with patience and old clothes it went smoothly enough. It was neither quick nor clean.
For this particular extraction, the emergency strap-on chains would probably have been a better choice. I only had to travel about 60 feet. Installing and removing the full chains was a messy, time-consuming business. I was stuck, so I had to drape the chains over the wheels, and then carefully spin the wheels just enough to get the chains on.
Now I have chains I can use on the road if I ever need them. I wouldn't mind owning the strap-ons also, but the convenience of the strap-ons wasn't enough to make me part with another $60 on top of the $100 I spent on the heavy chains.
tirechains.com was great. I called and spoke to them. They were friendly, knowledgeable, and they steered me away from some accessories I was considering. I recommend them without reservation. The chains are made in China, but they seem plenty robust and well made.
FWIW,
-jpg
http://tirechain.com/emergency_strap_on-suv-lighttruck.htm#1420
FWIW,
-jpg
