packratt
Active Member
Anybody got pics of the cam and crank timing marks?
The crank and cam should be at 12 and the IP pointing at them at 6. Which I think would be the same as crank at 12, cam at 6, IP at 12
The crank turns twice for each cam turn, so if its 180 off, you could disconnect the IP with the Crank at 12 and turn the crank once around to get the cam at 12 too.
Last time I did this was a long time ago but I thinkon the inside of the sprockets line up with timing marksthe small channel guides
