Big T
I have 158K miles on my truck and will be doing the Heath Cooling Upgrade. Should I be changing the timing chain while i'm in there? If so, what brand should I use?
Thanks,
Steve
Thanks,
Steve
At 4x the cost. One chain and sprockets will almost outlast the truck.I would replace with the timing gear set. Alot more reliable than a chain. :thumbsup:
Another question while waiting for the cooling upgrade kit: Should I replace the harmonic balancer?
Would be a very wise choice to.... Is the rubber cracked on yours? Engines can be ruined when one fails...
Matt wasn't the one you bought from Napa a Dorman.
Heath also sells Dorman......Lots of mixed reviews on Dorman Products......Luck of the draw?
