tireguy
Hey guys what should the timing be set at when doing a time set, i just got done installing a new ip want to get it right. Thanks
will have to try again. i cant find a place on the scanner that will tell what the base timing is although when you go into time set a screen pops up and says it whould be 3.5 degrees and if its not to loosen the pump and try again.
The base timing changes with moving the IP and is directly related to TDCO. The Time Set shows the base timing and it needs to be about 3.5, maybe a bit more while the desired is set to 0.
Attached I have timing info available on first and second pages that may be helpful.
The desired and measured timing under normal conditions are completely determined by the ECM program.
