NovaGuy
- Messages
- 28
- Reaction score
- 0
Drove to work yesterday. The truck ran great. When I got off work I fired it up it ran like it had a miss. Shut it down check to make sure all wires to the glow plugs where still on they where. Fired it up again ran the same. I figured I would drive it and hopefully that cylinder would kick in. well it didn't. Pulled over popped the hood opened the drain valve truck died. I grabbed the lift pump fuse. Touched to 12v felt the pumps vibe. Tried to fire it up wouldn't start. Primed the lift pump again then it fired still running the same. I the unplugged the oil preasure switch cut a piece wire from my amp.. Stripped the wire crossed the plug lift pump started working. Drove the truck no change. I stopped by a BMW perf. shop asked to use a 19mm wrench. I started cracking the injector lines all but the 2 under the turbo. Thinking air in one off the lines. The truck still running the same:nonod:. I decided to continue to drive the truck noticing some black smoke when i got on it. I got to thinking a injector might be stuck open. I then got on the HWY. The truck started running smother aroud 55mph. The died. I coasted to the side of the HWY. Tried to start the truck it wouldn't turn over. I figured it filled a cylinder with fuel and locked it. When we went to tow it I noticed fuel leaking from the drivers side of the block. Hopefully nothings hurt. Looking for new injectors to install.
