woodchuck2
As some may know i have had a problem with a coolant that the dealer claimed was a loose hose clamp :icon_bs:. Its been using coolant but not as much as before so maybe the clamp was part of the problem but 4 days ago i seemed to have an exhaust tick up front. With the plowing i do and getting it buried in snow i figured i bent the exhaust and possibly cracked the pipe at the manifold. So since the new service advisor and i have been bumping heads i decided to take the truck to a buddies garage to diagnose the problem myself before taking it to the dealer. I found the coolant leaking from the right rear head and the gasket itself is blowing by while running. I called the dealership i used to work at and spoke with a friend about working on it and i am having another friend tow it there in the morning. Hopefully they wont have it long as now i will be out of a plow/sander. I will be insisting on a 4X4 with at least a hitch so i can still work. I wish i had the coin to buy another truck now :mad2:.
