bmxdkj
As the title states, I have a 1999 Chevy, 6.5, PMD Relocated, soot trap removed and other than that the truck is bone stock. Always ran good up until a month ago, turned out to be a bad PMD. Replaced the PMD with a DTECH with a 6 foot extension cable routed infront of the radiator behind the grill. Just over the last week and a half the truck one morning was easy to start, and the very next morning, almost impossible to start. The temperatures between the two mornings were the same. So I suspected the glow plugs. Then just out of the blue last night I started the truck and it has a slight "skip," "thumping" out of the air intake, and low power/stalling issues have come up again. All the basics such as oil and fuel filters have been changed on a regular basis, glow plugs don't have much more mileage on them, maybe 50k or so and same with the injectors and injector pump. The DTECH was replaced today under warranty and the issue isn't resolved. The truck pours out alot of white smoke after start up, which is very unusual since this truck never did that. Also the truck loses power when you step on the throttle from a stop and slowly dies. PLEASE anyone with any ideas please help me out. Thank you everyone!
