Mad Maxx
See, what had happened was...
I got my new issue of Diesel Tech today in the mail and immediately found the new updates on their Duramax Build Up. This month they are covering the Turbo Upgrade, Trans. Build, and a modified CP3 from Industrial Injection.
While reading the Turbo section, they say they are using the PPE GT4094R Turbo to replace the Factory VVT Turbo the truck came with.
They say the Kit from PPE comes with everything you need (Turbo Pedestal, Oil Feed & Drain Lines, Longer DownPipe, and Compressor Inlet) all you need to do is get the Inlet Components to adapt your current Intake System to it.
Notice how the list above of included & required parts does not include an External Wastegate.
Is the GT4094R Turbo a VVT Turbo as well?? I'm pretty sure it's not, there is no speak of whether or not it is infact a VVT, and I know 100% you must use a wastegate on ALL Turbo's.
There are install pics and such in the article and I can't see an external 'gate anywhere.
What's the deal? How are they getting away with running that Turbo without any type of wastegate, and it not just spooling up to high hell and blowing to pieces.
