great white
Here's a thought I recently had that's mostly theoretical:
The "veggie guys" use a centrifuge to "polish" their fuel down to less than one micron. Aparently, it takes a couple passes also.
So, why couldn't a fellow install a 40-80 PSI pump and centrifuge system on our diesel truck to filter out impurities in the tank?
It would run while the truck ran and just go about it's business removing stuff from the fuel. Pull fuel out, spin it up, bits spin out, send the fuel back to the tank clean as a whistle. keep on filtering it until the truck is shut off.
It would have to be an independent circuit from the lift pump circuit, pulling fuel out of the tank and returning it filtered. May not work because of diesel foaming in the return.
I think it would make life a lot easier/longer on those media filters we all have installed in line, and would only require the occasional crawl under the truck to clean out the centrifuge.
Just something to think about and open for discussion.....
