TheDjost
I had the same problem. Stalling 25 to 30 seconds after a cold start. It did it everyday for 2 weeks. I took the piston out of the fuel shutoff solenoid and it hasn't stalled since. That was a week ago. I just took out the piston because I was too lazy to do a proper voltage test on the solenoid to check if it got enough power to open fully. No problems since, but I haven't run it all that much since I'm on vacation for the holidays. Now I'm changing the glow plugs, the controller and the harness. I'll probably test the solenoid when I'm done with that.
