RNation
Hello everyone. I'm tearing down my older 6.2 motor out of my 84 suburban for extra parts. The motor when together orginally had an issue with oil (alot of it) in the cooling system but not the other way around, then later on me and my friend had the heads checked (they turned out fine but weren't tested for flatness) then we put on new head gaskets but the motor ended up haveing water in oil and oil in water. I'm thinking we did the gaskets or the re-assembly wrong.
So my question is, is there any parts I should get rid of? And is there any certain way to store certain parts for an indefinate period of time?
So far I've wrapped the crank shaft and cam shaft seperatly in shrink wrap (lots of it) after wipeing them down with some oil.
Is there a way I can check the block to see if it's any good or not? One of the theorys on the oil in water problem (the original problem) was a cracked lifter bore, if that's so then the block would be nothing more than a heavy paperweight right?
