Well the reason I ask is I checked my timing today. It was 12.5 with a TDCO of 1.0. So would doing the relearn change it at all. I also just installed the GL4 and tried to the KOKO learn. Didn't get a stumble or anything but found out today that there was a boost solenoid code so figured thats why it didn't change.
What you are doing is setting a "window" of top dead center offset (advance or retard timing). depending which method/tool you use will determine your ease of setting exactly.
If you have a GM T2 tool or clone with same capability you possibly may be able to advance the or retard TDCO just by revving the engine and commanding learn, if there is sufficient "window" learn can capture a advanced position from factory, how much advance is determined by physical positon of the IP with relation to cam/crank/IP/timing chain slop to each other.
Those of us with "cave man" scanners, can only read current TDCO shut down and move IP advance/retard timing lock down command learn with ko/ko & APP to floor (OBD-II trucks only) then see what the resulting move did to change TDCO.
Remember TDCO is not base timing which can also be impacted by moving the IP, to set base timing like after a IP swap start truck, get up to operating temp and go to time set command, desired timing display will go to 0 degrees, and actual per factory spec should be 3.5 degs on average.
What I have found that if I set for 3.6-3.8 avg depending on vehicle when coming out of time set, that avg gets you TDCO pretty close to -1.5 TDCO more/less, and then only have to tweak just a little to set the desired TDCO you want.
Remember when in normal timing what you see displayed by timing actual/desired is wholly controlled by PCM/IP when engine is cold you will get higher timing as cold advance comes in via timer stepper motor advances, as engine warms up TSM backs out.
This is why engine has to be fully warmed up before making timing adjustments, or possible as son as it warms and influence of the TSM backs out you normal operating timing goes out of whack and you get odd idling or hesistaiton/stumble on acceleration or in reverse.
TDCO is a timing bias on top of the commanded time set by PCM, factory is (-.25 to -.75) better performance can be had with -1.5 to -1.94 wholly separate from time set, though physical movement of IP impacts both setpoints.
With a unknown vehicle I do time set 1st, establish the 3.5/3.6 avg lock down top IP lock nut, shut down, command via ko/ko APP to floor command, then restart and see where I am, if I'm happy with TDCO snug down bottom 2 lock nuts, if not rotate IP to direction I want TDCO to be. I only do time set 1 time to establish base time, after that I just tweak the IP to meet desired TDCO after that.
Does that clear it up more better ?
