It’s hard to start with one particular spot on what’s wrong with my truck. I have a 97 chevy c2500 with the 6.5 turbo diesel. I had a p1214 code and I used a tech 2 to find out I was at 2.46 degrees which should be .25-75 after 77c or 170 f. I ordered the 3 wrenches to adjust the pump. Adjusted the pump to where I assume correct would be. I’ve easily tried the koko method multiple times to do a relearn. Almost 20 times by now. I erase all the dtc on the truck. Press the gas and turn it off like the manual says for the 45 seconds then 30. I’ve tried adding more time to those as well. The second I turn the truck back on I get 2 codes. P1214 and p0216. I’ve watched the dtc codes live and the data display on my tech2. I’m stumped on what’s setting these 2 codes. I can’t find anyone local who works on these older diesels, I’ve called multiple dealerships and they had me track someone down a few hours away. I tried getting ahold of bill Heath the legend and that took days attempting to find him and nothing. I got ahold of Leroy from Leroys diesels and he thinks it might be pmd related so I ordered a new one but I’m a few hairs off from burning my truck down. I would really like to hear if anyone has any solutions.
