6.5TD Burb
I think mine may be dieing but I'm not sure.
Problem:
Doesn't take much to set if off. I'll drive home from work (est. 20-35 minutes depending on traffic and route), let it idle for a couple minutes to cool down and shut it off. Eat some dinner and maybe leave for short drive, elapsed time from shut down to start up again: 45-60 minutes. While I'll be buckling up it will stall. I'll hard wire the lift pump (addition from p.o.) for a few seconds, hold the accel. pedal on the floor and crank it for maybe 10-15 seconds till it starts again. It did this twice tonight. Once to go to church and once leaving church.
A new lift pump has not helped this and the pmd is only a few months old. New hoses from the filter housing to injector pump (didn't see any tears/holes in hoses from lift pump to filter housing), freshly rebuilt injectors with new 60Gs, new Delco fuel cap and (and I still get a copious amount of vacuum, think filling up a gas tank with gauge sitting on or close to "E"), new fuel filter and CDR. Vacuum pump has been checked and is showing nice and strong.
Still drives fine, some days it seems to have more power than usual though. Other than the sporadic (it's always in the same spot/s but not necessarily consistent (wording?)...go fig) "fishbite" it runs just fine.
Sound like a weak IP?
Problem:
