Swap S upper for F & leave the S lower?
Crankme69
Illinois the Corruption Capitol of USA
I'm picking up the EGR mystery gasket tomorrow am. I have a replacement F upper & lower intake to install. I have been reading & looking at pics, it would appear I can get the majority of the benefit by using the upper F and pounding the freeze plug with gasket into the existing S lower intake?
I can bolt the F upper to my S lower intake right?
I have already eliminated the EGR issues with a replacement custom chip, so that won't be an issue...
Oh & buy the way...the truck is running awesome just looking to help it breath a little better :D
TIA
I like your new Avatar, the wheels look good.
Attached are pics of the EGR intake. I think changing the upper is only about 70% of the benefit.
No EGR gasket with no EGR on the upper plenum. freeze plug seals what you would have been keeping out of the intake with that gasket.
The F intake has none of that stuff, just wide open space.
Thanks for the compliment Buddy!
I'm just a tad concerned about doing the lower until I do injectors. The mystery gasket can...can that be used with the freeze plug somehow to assure a tight seal? Like wrap it around it before I hammer it in?
The inside of my old upper and lower looked worse than Buddy's and everyone else that runs an EGER "S" set up.:eek:
This is what mine looked like after 10K miles with the "F" upper and lower swap. Unbelievable.:thumbsup:
Do yourself the favor since you have both the upper and lowers...10 or so bolts, clean some ground connections to the new lower while you're there, torque em down and have done with it.
The new F intake I bought on ebay didnt even have the little cylinder on the upper plenum, and it was smooth topped, no protruding shape of the EGR valve on top.
I think people that dont change the upper intake and only freeze plug the top part still need the mystery gasket to seal between lower and upper EGR tower/pillar.
If you freeze plug the lower plenum then exhaust gases cannot get into the intake at all.
Yeah, that's a small wonder of GM production but it is what it is and I got the whole set up for $100. Some have said to remove the cylinder, other's have said to leave it. I can't see it making that much difference.
I did some searching and came across this one from Turbine Doc on and earlier thread. http://www.thetruckstop.us/forum/showthread.php?t=19929&highlight=mystery+gasket&page=2
...freeze plug is one way of capping off EGR inside the plenum, another way is to put in new "mystery gasket" which is a 1 time use gasket labeled in some catalogs "GASKET-EGR VLV P" The ACDelco part # is 219-167 The GM part # is 10191428
Then put a .050" shim between the base of the EGR valve, and upper intake, which will block flow of EGR and still allow the vacuum system to cycle the actuator on the EGR valve so you don't code a EGR code.
FWIW, as an admitted diesel retard, I've replaced three sets of injectors and never once had to remove the lower intake...fender wells and turbo maybe for ease of access on the passenger side, but never the lower intake. Be brave, you've obviously got skills, so go for it. The gaskets between the lower intake and heads will take it.:thumbsup:
