dangbrewer
Hi, new to this site. I'm trying to change engines in a 1995 Chyenne 3500hd duelly diesel to a 350 small block. was told it will work. does anyone have any info on this swap?
X2Why?
Welcome!!!
I wonder the same thing?
The 350 is an engine for 1500 truck aka 1/2 ton truck while 3500HD is a 1 ton truck HD?
So you are trying to use a 1/2 ton truck engine to run 1 ton truck?
You will undersize everything and wonder why it will not run?
His 4L80E is a perfect choice (assuming its auto?). Just put a gasser TC on it. Any trans that was behind the diesel will work great with a gasser.
Yup the trans is the same, even a NV4500 will bolt up with the right clutch set up. GM offered all HD transmissions behind all engines in 2500 & 3500 trucks.
