2000 3500HD with low mileage (75000 Orig)
When I am going downhill or on a flat surface the engine surges often dropping as much as 800 rpm.If I move the accelerator pedal slightly it snaps back.
I also cannot press the accelerator while sitting still and maintain a constant rpm. It wants to jump from idle to 4000...
I have replaced and relocated the PMD and replaced the Pedal Position sensors but no change.
The ECM is not throwing any codes.
Installed a new fuel filter (the old one looked fine) and installed a new lift pump that is working fine as well.
If it was a fuel supply problem or air I think it would have issues climbing hills right?
Runs fine uphill and downshifts ok...
I have Boost/MAP sensor ordered...
Any Ideas?
