Supercharging
matuva
Tropical 6.5er
I have a customer willing to build a powerhorse on a 6.5
To do so, he wants to buy a Ted's engine, and put a supercharger on it. The goal is to reach 400 HP at the flywheel.
I have found a supercharger supplier who can sell a 400 HP kit, with different pulleys so you can adjust from 250 to 400 HP...
The seller says no need to lower comp to 18:1, even if it would be better.
That being said, how much can handle stock transmission?, trans, transfer, rear end....
They don't exactly give them supercharges away :eek: $4900 +
I would rather use a 12 valve cummins in da truck to get the 400+ ponies.
Matuva ,If the guy don't mind spending the money to build a strong engine i could sell you the 506 block in my sig.:agreed:
I don't seem to have the ambition nor the time to fart around with it anymore :nonod:
Nope,better than that. Specially build for me in China , machined to perfection :D
it has no outer main cap bolt holes, perfect for splayed mains or a solid combined main cap skirt to hold the bottom end together and prevent the common outer main bolt hole cracking.
