ghostrider500
Always stirrin' the pot
My 95 caprice with 4.3V8 does the above. It was running fine then had a slight delay when you put the accelerator to the floor; almost like a old 4-barrel carb would do. then the stumbling and stuttering started.
The fuel pump was only showing 5 psi so it was replaced...did not fix the problem.
The distributor was replaced(not by a AC Delco unit); problem still there.(Also replaced dist. harness from a forum vendor;Gary?) Plugs and wires are 3-4 months old; coil was replaced; problem still there.
Cleaned the MAF sensor; problem still there.
I got the Datamaster OBDI link up and have the ECU read-out; only problem is I don't know what I'm looking for. So I'm posting it here hoping someone can decipher it for me. It starts with the car cold; started and reved a few times; run out on the road at a speed that does not trigger the stuttering; after warm-up car was braked to a stop and then accelerator stomped to the floor a few times and you can really see the stumbling; driven back to the house, revved a few times and then shut off.
Any information would be greatly appreciated. Thanks.
http://s703.photobucket.com/albums/w...t=SDV_0085.flv
