97duallydiesel
The truck is running somewhat better now that I figured out that the Fuel filter was either cracked or wasn't tight and leaking air into the system causing it to stall and die.
I replaced the LP once again with a 93 LP, which wasn't that expensive. before I did this I checked the voltage to the LP with a volt meter when I turned the key on and it was reading 12. volts. I ran a new ground wire also, this was a problem before.
I decided to check all of my grounds and found one of the straps leading from the frame to the passenger rear was broken. I replaced that as well as the strap leading to the body. All other grounds where good.
I replaced the PMD ( Pensicola Diesel)and mounted it on a heatsync mounted to the top of the tranny cooler straps .( I removed the AC radiator awhile ago so there's alot of space between that and the coolant radiator)
Now the truck will sometimes start fine idle no problem but when I drive away it will stall. (Other times it wouldn't )I have to crank it several times and it will fire over and be fine. It will run no problem then all of a sudden hic-cup and get loud throwing a code P0251 .( Injection Pump Cam system) The truck still has power but it's almost like it's not getting fuel to all the cylinders.
My diesel mechanic says I need a new IP. I just want to make sure before I buy one. When I installed the PMD I put some dielectric grease in the connections . Could this be a culprit? Or maybe a bad wire harness??
