Stiffer Accelerator Pedal Spring
Will
Boobies make me happy
Mt. Pleasant, IA
This will not work on 06 and up trucks. That is a enclose unit.
One little things that has annoyed me about my truck is when ever I go over large bump or dip in the road is the pedal spring is to weak and I will end up "burping" the throttle. To remedy this problem I went to the local hardware store and bought a stiffer spring. The spring that I bought was 3/4" x 2 7/16' x .110
Here you can see a difference between the factory spring and the new stiffer spring. Factory spring is on top and the newer spring is on the bottom
vbpgimage.php
You will probably need a set of needle nose pliers to be able to bend the top hook on both the factory spring and the new spring. This makes it alot easier to remove and replace the springs. The top hook goes through a hole and the bottom hook fits in a groove on the side of the accelerator pedal.
Once the top hook is bent you can use the needle nose to pull the top
out of the hole. You might have to bend or twist the bottom hook a little to get it to slide out of the groove that it sets in.
When I replaced the spring I started at the top and put the top hook in first and then slid the bottom hook on. It slid one pretty easy but you might have to give it a little tug with the pliers.
New spring on(sorry for the blurry picture)
vbpgimage.php
I have an 2004.5 and it also throttle burps on bumps and it drives me nuts!. Do you think that it will work on an older truck?
i did it to my truck and i have same year as your truck canadien4x4. my freind has a lbz and his pedel was inclosed and no spring showing. what does he have to do to get at the spring.
My truck is a 04.5 also so this will work perfectly
I'm not sure. I haven't looked at an 06 and newer. I imagine that you could remove the whole assembly and pop the cover off but like I said, I haven't looked at one to know.
Awesome Mod!
I bought a set of springs at Lowes yesterday and took care of that horribly ****ified pedal. I used a 3/4"x2"x.105" spring, with the help of a heavy duty needle nose and an old key ring to get a good grip (and some cussing) it went on just fine. If anyone wants the other spring let me know I'll glady mail it out. Again, great thread and pics too!
