625fireman
I have injecter-itis
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). ____Throttle sticks when cold and surges at idle when warm________________________
- Year: __1994____
- Truck model and class (ie: c2500) __K3500_______
- Automatic or Standard _nv4500_________
- Mileage: (indicate miles or km) _87000________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) __PMD, ecm, throttle pedal, coolant sensor_________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? __f____________
- Ambient outside temp: (indicate *C or *F) __typical NE ohio ________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ____2_____
- What fuel additives are you using? ___none________
- Where are you located? __NE Ohio___________
- Air filter _spring 2008________
- Fuel filter __Feb 2009_______
- CDR Valve? ___never______
- Coolant – last flushed/replaced at ___aug 2008__________
- Oil – synthetic/regular, changed at ___Rotella faeb 2009________
- Batteries – state of charge, (matched set) replaced at __set Aug 2007___________
- Battery cables and grounds (removed, cleaned and tightened): ______yep________
- Glow Plugs - how many miles on them? __original_______ What type? _____________
- Injectors - last changed at ___orignial____________
- What were you doing when it happened? ___driving___________
- How was the truck running fine before this problem appeared? ________normal_____
- Has this problem ever happened before? ____constant since nov 2008___________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _y___ And? ___none_____
Diagnostics:
1] Starting:
1a] Does the engine start? ____yes_____
1b] Does the engine crank over? ___yes_____
1c] Are your batteries fully charged? ___yes______
1d] Have you removed, cleaned, and tightened all battery connections? ____yes____
1e] Does your Wait to Start light come on for a time? How long? ___yes 10 sec avg______
1f] Does your glow plug light come on? __saa _______ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? ___no_____
2a] Can you hear your lift pump working? ______yes______
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ____yes_____
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? _____yes______
2d] Loosen an injector line and crank the engine - does fuel come out? ____yes_____
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___no________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ____intake_______
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _____good____
3d] PMD Make: __stanadyne_________
3e] PMD Age: __new___________
4] Stalling Issues
4a] Do you experience stalling only when hot? ___n/a_________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ___n/a___
4c] Does pouring cool water over the IP seem to help with restarting? _____n/a____n/a
4d] Is stalling momentary (engine recovers)? __yes_______
4e] Does SES light come on when engine hiccups? _no________
4f] Does cruise control quit working when engine hiccups? ___n/a________
4g] Does re-starting seem to reset engine, restoring cruise and power? ____no_____
4h] Changes to dash lights or instruments during stalling events? ____no_______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? ____no___
5b] Any bubbles or oil film in coolant overflow tank? __no_____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? ____no______
5d] Excessive white smoke from exhaust on cold start? __yes_______
5e] Excessive black smoke from exhaust under hard acceleration? ___no_______
6] Performance Issues
6a] Do you have gauges? ___yes________
6b] Maximum boost under load? ____15________
6c] Have you added a performance PCM (reflash) or Chip? ______no________
6d] Have you changed exhaust / downpipe / crossover? __yes 3" straight______________
6e] Wastegate – mechanical or vacuum? ___mech___________
7a] Single or dual thermostats? __single__________
7b] Have you replaced them lately? Manufacturer of replacements? ____aug 2007_____
7c] Have you pulled and cleaned Radiator and coolers lately? ___aug 2007_________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ___no_____
7e] (winter) Have you tested your antifreeze? Good to what temp? ____-35______
7f] (winter) Are you using a winter grille cover? ____no_______
I have tried a bunch if things to try and stop the loping. It only does this when after the engine reaches 100* or so degrees.
1. I changed the coolant sensor on the crossover- no change.
2.swapped the throttle pedal- no change.
3.swapped the ecm- no change.
4. new pmd -no change
5. grouned heat sink to IP- no change
6. cleaned all grounds- no change
7. pulled hair out- no change
If I lugg the engine down at idle(just momentarily to stop the loping) it will quit loping for about 5 mins but it wil eventualy start doing it again.
The newest thing is when cold the throttle will stick if I rev over 2,000 before I shift.
I am thinking my IP is going out what do you think???? Am I on the right road or do I head in another direction??
TIA Joe
- Year: __1994____
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
TIA Joe
