Steering parts...
You might post a vendor request also but I've had good pricing from RockAuto on alot of OEM equivalent replacement parts.
Lift one side up and grab hold of that tire at 3&9 oclock, wiggle back and forth and watch for movement in those parts. There should be next to none.
Chad, I'm not quite sure what you mean. Could you post a pic of the idler bracket and what you are concerned about? Typically there isn't a problem with any wear on them that I'm aware of.
The shaft that goes thru the bracket is greasable and can wear use the same test you just did and look for movement in the shaft not the ball end. Easiest way takes 2 people have one turn the steering wheel quickly back and forth while the other watches for movement.
Try posting something in the want ads. Someone here on the site might have their old stuff they replaced with heavier duty stuff.
so...if there is movement, does the arm need changed or the bracket too?
