RNation
Hey fellows, been awhile since I was around here last. Been pretty busy with work.
Anyhow, my last issue was the steering or gear box (I think thats what it was called, sits on the end of steering shaft) was leaking fluid. Now I have a kind of new thing going on and I'm wondering if it's related to the gear box. The only way I can explain the noise is that it's the screeching noise you hear when you turn the steering wheel too far to either side. Well I get that noise sometimes when steering too fast while the truck is barely moving. It gets alot worse in the winter, to the point that I almost got stuck in a parking spot one night becasue the steering wheel wouldn't move enough without screeching up a storm. It makes the noise with the power steering reservoir full on fluid.
So I'm wondering if the gear box would cause that issue. Also the power steering pump is no older than 2 years but I think it may be closer to 1 1/2 years. And I just remembered, when I have to hit the brakes hard it makes the same exact screeching noise.
Thanks in advance
Thanks in advance
