figment
A junkie for the purr of a 6.5L
Well I think that my starter soleniod isn't up to snuff. Has anyone had the problem of the starter not fully engaging? I usually use the the command start to start it, but today I was across the the parking lot at work and heard it start too turn over but then it started grinding like it wasn't fully engaged with the ring gear like it slipped out of the teeth. I shut it off as soon as I heard it start to grind, I crawled under to make sure the starter bolts hadn't backed out, or the connections were lose but everything was tight. I hopped in and just started it with the key and it started like it should. :thinking:
Are these known to go bad? Is there a way I can rebuild it? I'm pretty strapped for cash right now, and I can hold my own with a set of wrenches.
I haven't had the time to inspect the ring gear as of yet. Life seems to have delt me a crappy hand right now and I'm struggling keep my skin right were it is. So ANY idea's and all suggestions would be greatly appreciated.
